Hi all,
I have an option to buy a BC2500. Not expensive, but a problem is the tuner doesn't work right. Seller says the automatic search doesn't work OK.
Can't find anything on the forum on this. Checked out the service manual, it says that in case of tuner trouble they advise to replace the entire tuner board.
Are these tuners hard to fix? Probably all SMD components? I know how to fix stuff but never handled SMD before.
Anyone who has some experience with this?
