Latest post 12-01-2011 6:31 AM by Roger. 5 replies.
Page 1 of 1 (6 items)
  • 11-30-2011 11:35 AM
    • dueno
    • Top 500 Contributor
    • Joined on 04-29-2007
    • bordeaux
    • Posts 147
    beo5 to beo 6
    is it possible to update a beo5 to beo6?
    never explain never complain
  • 11-30-2011 12:00 PM In reply to
    Re: beo5 to beo 6
    Yes it is.
    If a Beo5 gets a faulty screen, the screens are no longer made, so B&O produced a kit to upgrade it to a Beo6
    Regards Keith....
  • 11-30-2011 12:53 PM In reply to
    • dueno
    • bordeaux
    • Posts 147
    Re: beo5 to beo 6
    and then have we got the wifi?
    what is the price of the kit?
  • 11-30-2011 1:09 PM In reply to
    Re: beo5 to beo 6
    Yes, you do have WiFi once the new firmware is downloaded into it by your dealer
    Regards Keith....
  • 11-30-2011 3:00 PM In reply to
    • petermc
    • Joined on 04-16-2007
    • Shepparton, Australia
    • Posts 87
    Re: beo5 to beo 6
    That sounds promising - any idea of the cost?
    Peter
  • 12-01-2011 6:31 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: beo5 to beo 6
    In my neck of the woods the cost was so high, that trading in the old Beo5 for a new Beo6 turned out to be a better deal. Check with your dealer (if the workshop charge you by the hour for the repair you are better off getting a new one IMHO).
    Roger
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
