Latest post 12-01-2011 3:37 AM by DrDimitris. 3 replies.
Page 1 of 1 (4 items)
  • 11-29-2011 2:15 PM
    sky hd to dvi bv7 mk1
    Hi Guys,
      Sorry if this has been asked before!  I have searched and not found the answer, If I want to connect my sky hd to my bv7 mk1 how do i do it? I hear that dvi doesn't carry sound( no pun intended!) and how would i then distribute it via masterlink? Cheers Nick
  • 11-30-2011 3:47 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: sky hd to dvi bv7 mk1
    If it's a Mk1 then you first need to check if it's HD upgraded - otherwise the only option you have is scart!
    All BV7-32's, right up until the last one to leave the factory, were 720p HD - but the very early ones didn't have the scaler fitted so you could watch things like Sky HD through the DVI.
    Lee
    Smile
  • 12-01-2011 1:41 AM In reply to
    Hi Lee,
       its the one I had from you!  it is hd ready its got a dvi-hdmi adapter in the back, so i have sky hd and wondered how to connect the sound and how do i send the link signal?
    Thanks Nick
  • 12-01-2011 3:37 AM In reply to
    I have the same setup Nick with an HD-ready MKII. You need a coaxial audio cable to run from SKY HD to Bv7. Assign port A1-A4 in the CONNECTIONS MENU.
    For masterlink distribution you have to connect also SCART from SKY HD to Bv7. Easy. Of course on HD on link rooms but ok.
    Hop this helps
    -Dimitris
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
