Latest post 11-14-2011 3:24 AM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 11-13-2011 10:47 PM
    • KalK
    • Not Ranked
    • Joined on 09-10-2009
    • Posts 27
    What is the difference between
    Beomaster 5000 and Beomaster 5500? Would the remote for 5000 work for 5500 as well?
    Cheers
  • 11-14-2011 3:24 AM In reply to
    Re: What is the difference between
    No, the codes used are completely different.
    The MCP 5000 only works for the Beosystem 5000 and the MCP5500 only for the Beosystem 5500/6500/7000
    Regards Graham
