First, I would like to say that I am new to BEOWORLD, so "Hello" to all.
I got
 a Beomaster 900M with 2 B&O HOJTTALER 3-5 OHM TYPE B Speakers from a retired co-worker,
which he bought in 1967. Unfortunately his grandsons did some "investigations" - removed the bulbs a.s.o.
When I opened the Beomaster I noticed a loose blue-and-white wire and I have no idea where to solder it.
Perhaps another 900M owner would be kind enough and take a look on this board and the loose wire
and helps me to find the right soldering point ?
Photo can be sent by PM.
Thank you !
Joe
