Latest post 11-02-2011 4:04 PM by beo900. 2 replies.
Page 1 of 1 (3 items)
  • 11-01-2011 2:06 PM
    • beo900
    • Not Ranked
    • Joined on 11-01-2011
    • Posts 2
    Beomaster 900M - the loose wire
    First, I would like to say that I am new to BEOWORLD, so "Hello" to all.
    I got a Beomaster 900M with 2 B&O HOJTTALER 3-5 OHM TYPE B Speakers from a retired co-worker,
    which he bought in 1967. Unfortunately his grandsons did some "investigations" - removed the bulbs a.s.o.
    When I opened the Beomaster I noticed a loose blue-and-white wire and I have no idea where to solder it.
    Perhaps another 900M owner would be kind enough and take a look on this board and the loose wire
    and helps me to find the right soldering point ?
    Photo can be sent by PM.
    Thank you !
    Joe
  • 11-01-2011 3:04 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 900M - the loose wire
    Welcome to Beoworld !
    What a nice set !
    The wire, is it this one of these on the amplifier board ?
  • 11-02-2011 4:04 PM In reply to
    • beo900
    • Not Ranked
    • Posts 2
    Hi Martin,
    yes the one on the right hand side.
    Regards,
    Joe
