Hello,
I recently purchased a Beolab 2000 which I wanted to connect to my Beosound 2300.
Obviously, the BS2300 do not have Masterlink so I also purchased a Beolink converter.
However, when I tried to connect it tonight, I was unable to get any sound to the Beolab 2000 and before I rule out the Beolink converter as faulty, I would like to get your opinion regarding the setup and if I have done something wrong.
First of all, some info about the Beolink converter:
Type: 1611
SW 1.3
As I have understood, this should be the model that is used to connect the Beosound 2300 to a Masterlink product.
The cables I have used is a Masterlink cable (obviously) and a Datalink cable from Soundsheavenly. I have connected the Datalink cable from the AUX socket on my BS2300 to the AUX socket on the converter.
Furthermore, when I plug in the converter, I cannot hear any sound of it turning on so I thought that could indicate it as faulty (but maybe that's normal).
Would really appreciate your help!
Best regards,
