Latest post 09-29-2011 10:40 AM by Zwets. 2 replies.
Page 1 of 1 (3 items)
  • 09-29-2011 7:08 AM
    • fridsten
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Stockholm, Sweden
    • Posts 167
    HDR1 and DVD1 with BV6-26
    Hi!
    It's been a long time since I was here, mainly because of a new job and a new apartment, which have taken quite a bit of my time.
    Now, though, I'm ready to ask a serious B&O-related question. :)
    I have a BV6-26 from 2005 with a DVD1 connected to it. (Some of you may recall my HTPC build, but unfortunately it broke down.)
    Now I'm considering buying a HDR1 so I can record TV programs as well, since that's a feature that I'm currently lacking. I know that the DVD player is controlled from the Beo4 via the TV. Does the HDR1 work the same way? And can I connect both of them to the TV?
    How do I go about this?
    Thanks!
    /Fredrik
    Filed under: , ,
  • 09-29-2011 7:58 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: HDR1 and DVD1 with BV6-26
    Hi Fredrik,
    there is a set-up guide here on site.
    It explains how to connect the HDR1 to different TVs.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 09-29-2011 10:40 AM In reply to
    I used to have exactly this setup. I worked great. Offcourse with the HDR1 you cannot record digital TV so now on my new BV-8-40 I no longer use the HDR1.
