Latest post 09-20-2011 2:26 PM by Rup. 2 replies.
Page 1 of 1 (3 items)
  • 09-20-2011 12:06 PM
    • Rup
    • Not Ranked
    • Joined on 09-20-2011
    • Posts 2
    Beomaster 2000 Phono/Vinyl/LP Cable Making Ground
    Hi there,
    Bit of a noob but here goes...
    I've just got a Beomaster 2000, which has lovely sound on radio and TP phono inputs.  I've got a nice old Lenco record player which works very nicely, but I'd like to connect it to my new Beomaster.  I've trawled the forums here as best I can, and am making a cable to connect it - I'm using a 5-pin din connector (fun to use, since I'm using massive solid core wire in an attempt to avoid any signal loss), rather than 7-pin, as, so far as I can gather, the other 2 pins are only used by the B&O products for the whole data-link thing, and the 5 align wih the right ones on a 7 socket. (Hope that makes sense)
    Anyway, I've soldered on as follows:
    Pin 3 - Left
    Pin5 - Right
    Pin2 - Signal Ground (From Both L&R)
    Pin4 - Nothing
    Pin1 - Nothing
    As far as I can see this is right from what others have said, but please correct me if I'm wrong.
    My basic question is this:
    Where do I connect the External ground wire from my record player?
    I'd guess I either have to connect it to the shell of the DIN plug, or onto a case screw on the Beomaster 2000, but I have no idea which, or if it should be somewhere else entirely.
    Thanks for all your help and consideration!
    Rupert
    Filed under:
  • 09-20-2011 12:53 PM In reply to
    Re: Beomaster 2000 Phono/Vinyl/LP Cable Making Ground
    Rup:
    The shell of the DIN is where it goes officially, so you can use that as you are building the cable from scratch anyway. The case of the Beomaster would work as well. As far as I can see you have everything else correctly.
    Good luck and welcome to the forum Smile
    -mika
  • 09-20-2011 2:26 PM In reply to
    • Rup
    • Not Ranked
    • Posts 2
    Hi Tournados,
    Thanks so much for your reply, wired it into the DIN plug, and works really well, lovely tone and almost no noise (no hum at all)!
    Ace Thanks!
