Hi there,
Bit of a noob but here goes...
I've just got a Beomaster 2000, which has lovely sound on radio and TP phono inputs.  I've got a nice old Lenco record player which works very nicely, but I'd like to connect it to my new Beomaster.  I've trawled the forums here as best I can, and am making a cable to connect it - I'm using a 5-pin din connector (fun to use, since I'm using massive solid core wire in an attempt to avoid any signal loss), rather than 7-pin, as, so far as I can gather, the other 2 pins are only used by the B&O products for the whole data-link thing, and the 5 align wih the right ones on a 7 socket. (Hope that makes sense)
Anyway, I've soldered on as follows:
Pin 3 - Left
Pin5 - Right
Pin2 - Signal Ground (From Both L&R)
Pin4 - Nothing
Pin1 - Nothing
As far as I can see this is right from what others have said, but please correct me if I'm wrong.
My basic question is this:
Where do I connect the External ground wire from my record player?
I'd guess I either have to connect it to the shell of the DIN plug, or onto a case screw on the Beomaster 2000, but I have no idea which, or if it should be somewhere else entirely.
Thanks for all your help and consideration!
Rupert
