Hi all,
After a couple of remotes for specific systems;
All Black MCP 6500 and / or a White BL1000
Also interested in any other White remotes out there as well.
Cheers
GUY
Train Hard - Run Fast - Hit to Kill!!!
There is a member (Craig I think?) who sprays BL1000's to good effect.
Olly.
Step1: There is a member (Craig I think?) who sprays BL1000's to good effect.
Are you sure? I've sprayed these "Iconic designs" also, so do other members
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
The only all black MCP was designated MCP 7000 (with no technical difference)... good luck finding one of them either, though!
-mika
Never knew that there is or better was an original black MCP. Is it called MCP7000?
Leslie: Never knew that there is or better was an original black MCP. Is it called MCP7000?
I found the old thread - I remembered incorrectly, apparently it had no number at all but was sold only with black BS7000s.
I think Lee has one nowadays (or at least his avatar had ).
Sorry Mika, again I could have searched the BW for that myself. Still learning and a bit lazy...
Leslie: Step1: There is a member (Craig I think?) who sprays BL1000's to good effect. Are you sure? I've sprayed these "Iconic designs" also, so do other members
You're both right although Craig actually has access to powder coating which is a little more robust.
Chris.
Quite right, powder coating
