Latest post 09-13-2011 2:22 PM by Leslie. 8 replies.
Page 1 of 1 (9 items)
  • 09-12-2011 5:25 AM
    All Black MCP6500 or White BL1000
    Hi all,
    After a couple of remotes for specific systems;
    All Black MCP 6500 and / or a White BL1000
    Also interested in any other White remotes out there as well.
    Cheers
    GUY
    Train Hard - Run Fast - Hit to Kill!!!
  • 09-13-2011 3:57 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Re: All Black MCP6500 or White BL1000
    There is a member (Craig I think?) who sprays BL1000's to good effect.
    Olly.
  • 09-13-2011 10:17 AM In reply to
    Step1:
    Are you sure?Hmm I've sprayed these "Iconic designs" also, so do other membersBig Smile
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 09-13-2011 10:31 AM In reply to
    The only all black MCP was designated MCP 7000 (with no technical difference)... good luck finding one of them either, though! Smile
    -mika
  • 09-13-2011 10:50 AM In reply to
    Never knew that there is or better was an original black MCP.  Is it called MCP7000?
  • 09-13-2011 11:05 AM In reply to
    Leslie:
    I found the old thread - I remembered incorrectly, apparently it had no number at all but was sold only with black BS7000s.
    I think Lee has one nowadays (or at least his avatar had Laughing).
    -mika
  • 09-13-2011 11:20 AM In reply to
    Sorry Mika, again I could have searched the BW for that myself. Still learning and a bit lazy...
  • 09-13-2011 2:17 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Leslie:
    Step1:
    You're both right although Craig actually has access to powder coating which is a little more robust.
    Chris.
  • 09-13-2011 2:22 PM In reply to
    Quite right, powder coatingHmm
