Normally the system checks itself if there are updates available (unless you unchecked it in the menu). After this update there is no screen with some info like other (major) updates. This is normal because it is a minor update
This release has number 6.04.00.2871.
When you press ">>GO" you can see @ product info a new line "last N-radio update 2011-09-14" (this is a new info line)
Mine is working much better now (only issue with some FLAC files which are not recognised by mots, but this is not a major bug for me)
It didn' stall anymore, start up is quickly etc
I did also a "delete databases" to clean up the system.
You can find this after pressing "><><GO" under maintenance.
It took several hours to do that, but I have the impression it is not so bad doing this when you have problems with the system. I do not know which databases it deletes, but when you select it, it will reboot and i see in the log files it is updating some parts of the MOTS databases. I have 40.000 mp3/flacs on the disk and after 1 night the system was backup and running, so it is not deleting the entire mots database
nico
