Latest post 08-26-2011 8:00 PM by mhw. 3 replies.
Page 1 of 1 (4 items)
  • 08-23-2011 11:39 AM
    • mhw
    • Top 500 Contributor
    • Joined on 06-29-2007
    • Norway
    • Posts 207
    • Gold Member
    Thickness of Masterlink cable
    Quick question: How thick is a Masterlink cable?
    I'm going to buy some cable ducts and want to make sure they are big enough!
    Magnus
  • 08-23-2011 1:42 PM In reply to
    Re: Thickness of Masterlink cable
    Magnus,
    Standard B&O Masterlink cable part Number 6250422 is 7mm dia
    The internal wires are 24 AWG size
    Regards Keith....
  • 08-23-2011 2:20 PM In reply to
    I would not use Masterlink cables anymore. Use CAT7 cabling with RJ45 sockets and RJ45 to ML connectors and you are much more future proof.
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 08-26-2011 8:00 PM In reply to
    • mhw
    • Norway
    • Posts 207
    • Gold Member
    Thanks a lot Keith!
    And I agree about Cat7, but this is a relative short run so Masterlink is easier. But if I'm going to do some longer runs, I'll use Cat7! Thanks for the tip!
    Magnus
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
