Latest post 10-18-2011 2:42 AM by hemenex. 3 replies.
Page 1 of 1 (4 items)
  • 08-15-2011 10:23 PM
    Form 1 Headphone replacement foam?
    After a few years in storage, I took my Form 1 headphones out, tried to use them, and the earpiece foam completely disinigrated into tacky  black dust!
    I talked to local B&O dealer, and they tell me replacement foam is not available.
    Do any of you know a source for this foam?
    Thanks!
  • 08-16-2011 8:32 AM In reply to
    Re: Form 1 Headphone replacement foam?
    • B&o bottle opener
  • 10-17-2011 8:02 PM In reply to
    What kind of Glue for: Form 1 Headphone replacement foam?
    Thanks to your info, I now have the foam replacements for the Form 1 headset.  What glue would you recommend for putting it on?   The foam has a smooth-shinny paper adheared to the back.   At first I thought it was peel & stick, but it does not come appart.   The backing is very slick & plastic like.
    Anyone glued up earpeace foam lately?
    Seahawk
  • 10-18-2011 2:42 AM In reply to
    Re: What kind of Glue for: Form 1 Headphone replacement foam?
    seahawk:
    Is IS peel & stick; at least the original ones I ordered beginning of his year.
    It is a bit complicated though as if you do it wrong you rip the glue off as well: I had a knife inserted under the "carrier paper" to seperate it.
    Yes they are still available: #3917087
      Gunther
