Hello everybody
I bought two round IR eyes on the bay and One of them is a particular model.
The second is like the one we use with beolink passiv (5 connectors on the back and buttons on the front).
The other has the same buttons but the card inside is different.
There are 6 connectors (white instead of green).
This is not a IR eye for beosystem because they don't have buttons.
THis is not a IR eye for a charger of a beolink 7000 because the buttons are different.
It looks like it's another model.
Do you know this model and the way to wire it ?
Thanks for your help.
Best regards
OLivier
