Latest post 10-14-2011 10:13 AM by Christophe75. 10 replies.
Page 1 of 1 (11 items)
  • 07-16-2011 8:00 AM
    strange round IR eye
    Hello everybody
    I bought two round IR eyes on the bay and One of them is a particular model.
    The second is like the one we use with beolink passiv (5 connectors on the back and buttons on the front).
    The other has the same buttons but the card inside is different.
    There are 6 connectors (white instead of green).
    This is not a IR eye for beosystem because they don't have buttons.
    THis is not a IR eye for a charger of a beolink 7000 because the buttons are different.
    It looks like it's another model.
    Do you know this model and the way to wire it ?
    Thanks for your help.
    Best regards
    OLivier
  • 07-16-2011 1:56 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: strange round IR eye
    Photo???
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 07-16-2011 2:37 PM In reply to
    Sound like an IR eye with autocontrast.  Used on a BeoSystem with drop down screen, a BV7 with projector where the screen blocks the IR, or an early BV4 without the zit on the top.
  • 07-16-2011 2:53 PM In reply to
    Thanks for your reply
    I don't konw how to add pictures (I use linux).
    It should be for a beovision TV
    Don't know what to do with it now.
  • 07-17-2011 2:57 PM In reply to
    For a very short time, there were round MCL eyes which look very similar to those used for ML. Similar to the BL 7000 charger but no charging connections. Rare to find. I think they are very nice!
  • 07-17-2011 3:42 PM In reply to
    Thanks Peter for your reply
    I have read this kind of information by googling, but I don't know how to use it in a MCL system and how to wire it.
    Its face is like a normal one, buttons mute on top and play.
    It's useless for me at this time.I just need an IR eye for a beolink passiv.
    Any more information/datasheet welcome ;)
  • 07-18-2011 3:51 AM In reply to
    I asked to someone who owns a IR eye for a beovision and he tolds me that there is no buttons on it.It is just a receiver.
    So, I just have to discover if the MCL round IR eye has buttons and how to wire it.
    The story goes on ...
  • 07-18-2011 4:18 AM In reply to
    • kallasr
    • Posts 1,077
    Photos:
    1. Choose to post/reply as normal
    2. Click on the "Options" tab near the top of the compose screen
    3. Under file attachment select "add/update
    4. Browse directories, upload, etc.
    OR
    1. Compose message as normal
    2. Select "options" from the tab
    3. Under file attachment select "Add/Update"
    4. Enter the URL where an existing file resides.
    OR
    1. Compose mesage as normal
    2. Select the image icon from the formatting palette
    3. Enter url
  • 07-18-2011 5:35 AM In reply to
    Thanks for your answer.
    On my system, I cannot browse my directory if I use your link.I use linux mint and Firefox
    The seller of this IR eye, just told me that it is for a beolink activ.
    Are they different compared to those for beolink passiv ?.
  • 07-18-2011 7:54 PM In reply to
    kallasr:
    Photos:
    OR
    OR
    3. Enter url
    or,
    -open the picture in another application
    -select all
    -copy
    -paste into text box
    My B&O: 2009 Catalogue and Pricelist
  • 10-14-2011 10:13 AM In reply to
    Hello Peter,
    would they look like this one ?
    (the front of this one is same as BL active/passive : Timer/up/down/play buttons)
