Latest post 04-23-2011 2:09 AM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 04-19-2011 8:02 AM
    Scrap Beomaster 3000-2
    I am looking for some low profile motorola 2n3055 output transistors to refurbish a 3000-2. These were also used in the beocentre which used to same output board. If necessary I will buy a complete unit.Thank you in advance
  • 04-19-2011 2:53 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Scrap Beomaster 3000-2
    Welcome to Beoworld and thanks for signing up as a silver member, your support is greatly appreciated !
    B&O generally used 2N3055 transistors from RCA in the late 1960's but motorolas are also found
    in the later builds.
    Are you looking for both pairs or just one ?
    Factory new (NOS) or original used ?
    I take it, you are aware of the possibility of buying counterfeit parts ?
    You can read a little more here:
    http://forum.beoworld.org/forums/t/2388.aspx
  • 04-21-2011 7:03 AM In reply to
    Hi Martin, I am looking for just one pair. Original used would be fine or factory new. Yes I am aware that there are counterfeit ones about.
    Jim
  • 04-23-2011 2:09 AM In reply to
    • Dillen
    • Posts 5,008
    Found a pair.
    They are identical and has worked together. Low profile, suitable long pins for use
    in the Beomaster 3000, original vintage, used, tested good and from Motorola:
    You have a PM (check your inbox).
