I am looking for some low profile motorola 2n3055 output transistors to refurbish a 3000-2. These were also used in the beocentre which used to same output board. If necessary I will buy a complete unit.Thank you in advance
Welcome to Beoworld and thanks for signing up as a silver member, your support is greatly appreciated !
B&O generally used 2N3055 transistors from RCA in the late 1960's but motorolas are also foundin the later builds.Are you looking for both pairs or just one ?Factory new (NOS) or original used ?
I take it, you are aware of the possibility of buying counterfeit parts ?You can read a little more here:http://forum.beoworld.org/forums/t/2388.aspx
Hi Martin, I am looking for just one pair. Original used would be fine or factory new. Yes I am aware that there are counterfeit ones about.
Jim
Found a pair.They are identical and has worked together. Low profile, suitable long pins for usein the Beomaster 3000, original vintage, used, tested good and from Motorola:
You have a PM (check your inbox).Martin
