Nobody??
No one else has any information about what's new in beosystem 3?
On bang-olufsen page the only difference I see that the plasma is connected with HDMI .
Thank you
BeoVision 4 - 85"
DESIGNER David Lewis
DIMENSIONS (W x H x D)/WEIGHT On wall bracket:
205.2 x 126.9 x 22.1 cm/163 kg including wall bracket
Floor stand:
205.2 x 187.1 x 95 cm/480 kg including floor stand
COLOUR(S)
Frame: Silver, black, red, blue, dark grey, golden
CONTRAST SCREEN Contrast screen with anti-reflection coating
POWER CONSUMPTION EU: Typical (IEC 62087:2. ed): 375 W/Networked standby 0.4 W
MAINS VOLTAGE RANGE EU/US/Japan: 200-240 V ± 10 %, 50-60 Hz
OPERATING CONDITIONS Temperature: 0-40° C, 32-104° F
Humidity: 20% - 80%
Minimum outside air pressure:
In use: 756 hPa
In storage and transportation: 700 hPa
SCREEN TYPE 85" 16:9 Plasma display panel
RESOLUTION 1,920 x 1,080 Progressive (Full HD)
3D FUNCTION Requires active shutter glasses
LUMINANCE OF WHITE (CENTRE OF SCREEN) 160 cd/m2 (typical)
CONTRAST RATIO (CENTRE OF SCREEN) 30,000:1 (typical), max 5,000,000:1 (peak)
PICTURE OPTIMISATION VisionClear
ROOM ADAPTATION Automatic Picture Control
COLOUR CALIBRATION Automatic calibration runs for every 100 hours
PLASMA CONNECTION Picture: 1 x HDMI
Control and Automatic Colour Management : 1x RS 232C
IR and AutoContrast: 1x D-sub 9 pin
PLACEMENT OPTIONS Wall bracket
Floor stand
ACCESSORIES 3D glasses
REMOTE CONTROL Beo4 or Beo6 - Optional
