I'm looking for the belts for the CD and for the tape lid.
Does anyone know where to get them (would be nice if I can order them on the Internet)?
Hi! Suggest you contact Martin, (Dillen on this site). He is the 'belt expert' on the site & it's almost certain he can either help or, point you in the right direction.
Regards
John
If not at Martin
http://stores.ebay.com/Marrs-Communications?_rdc=1
Has B&O belt kits for almost everything
Menahem
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
The belts are still available at your Bang & Olufsen dealer, in that case you are sure you get the right ones!
