Latest post 05-05-2011 4:25 PM by Blackrix. 3 replies.
Page 1 of 1 (4 items)
  • 04-18-2011 5:06 AM
    • covent
    • Not Ranked
    • Joined on 03-12-2011
    • Stockholm, Sweden
    • Posts 26
    • Silver Member
    Belts to CD and tape lids on Beocenter 9500
    I'm looking for the belts for the CD and for the tape lid.
    Does anyone know where to get them (would be nice if I can order them on the Internet)?
  • 04-18-2011 7:22 AM In reply to
    Re: Belts to CD and tape lids on Beocenter 9500
    Hi!  Suggest you contact Martin, (Dillen on this site).  He is the 'belt expert' on the site & it's almost certain he can either help or, point you in the right direction.
    Regards
    John
  • 05-05-2011 2:53 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    If not at Martin
    http://stores.ebay.com/Marrs-Communications?_rdc=1
    Has B&O belt kits for almost everything
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 05-05-2011 4:25 PM In reply to
    The belts are still available at your Bang & Olufsen dealer, in that case you are sure you get the right ones!
