- Lamp housing and lamp socket - that black triangle that holds the window in place + the socket for the lamp. Same parts are used for the Stereo-Lamp on the 1100 series.
Two different types for the Stereo and Tuning lights.
The one for the red Tuning lights has two lenses, Stereo has only one.
- Balance-Slider. I guess this is the same as in the BM 1400/1500? Certainly looks a lot like it. Dimensions are 3x2,5x0,8cm.
Dimensions are the same but I only have with orange line (Beolab 1700 is unique green).
I can find three identical windows.
- Both side panels - same as in the 1100/901?
1100 and 901 are of different height and both are found in metal or plastic.
You need the same as for the 1100.
I have a pair in plastic, need new veneer.
- One of the wedges that hold the lower/upper front panel in place. Same as in 1100.
Yes.
