Latest post 04-14-2011 8:04 AM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 04-14-2011 6:08 AM
    Need spares for a Beolab 1700 (BM1100/BC1500/1600/1800)
    Finally got a Beolab 1700.
    Unfortunately one of them fixers got his hands on it before me…so now I need some parts that are missing.
    - Lamp housing and lamp socket - that black triangle that holds the window in place + the socket for the lamp. Same parts are used for the Stereo-Lamp on the 1100 series.
    - Balance-Slider. I guess this is the same as in the BM 1400/1500? Certainly looks a lot like it. Dimensions are 3x2,5x0,8cm.
    - Both side panels - same as in the 1100/901?
    - One of the wedges that hold the lower/upper front panel in place. Same as in 1100.
    Would be great if someone had some of these...
  • 04-14-2011 6:22 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Need spares for a Beolab 1700 (BM1100/BC1500/1600/1800)
    Two different types for the Stereo and Tuning lights.
    The one for the red Tuning lights has two lenses, Stereo has only one.
    Dimensions are the same but I only have with orange line (Beolab 1700 is unique green).
    I can find three identical windows.
    1100 and 901 are of different height and both are found in metal or plastic.
    You need the same as for the 1100.
    I have a pair in plastic, need new veneer.
    Yes.
  • 04-14-2011 7:31 AM In reply to
    Wow, now that's fast!
    Great! Exactly what I need. I've sent you a message.
    The Beolab has a single lamp, so I'll need the one-lens-housing.
    Removing the orange paint and replacing it with green one shouldn't be that hard. And I still have some matching veneer for the panels.
    I guess I'll never figure out why they fixed it this way - cut the connections to the lamp, removed everything, wired a glow lamp directly across the mains and taped it to the window. Why?! The schematics are in there - is it really that hard to get a 30mA lamp?
  • 04-14-2011 8:04 AM In reply to
    • Dillen
    • Posts 5,008
    Yes, it is getting more and more difficult to get the right lamps, I get more and more requests.
    Two types are used in these machines, the stereo and tuning lamps are not of the same wattage.
    I can supply both types.
