1st March February 2012
Latest post 12-14-2011 6:02 PM by Leslie. 71 replies.
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
Re: cx50 refurb with pictures!
Leslie:
What did you do with the B&O text on the front and the stripe on the sides?
You may be able to reproduce the font with Helvetica Lettraset. Not sure what font size you'd need.
The stripes can be done using THIS guys vinyl pinstripes - really good quality graphic stripes. I've used his black ones on CX50's & 100's with good results.
Chris.
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Nickyg63:Painted over, I'm afraid!
Same as mine. Don't have any alternatives fore the text but for the stripes on the side you can use transparent laquer. Just tape the sides off.
For the black I have been using a sort of glossy tape which they use for making lines on a whiteboard.
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Medogsfat:
Leslie:
Chris.
Use Beofont.ttf. search the net or here, I dont remember where but its somewhere
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Leslie
- Netherlands
- Posts 2,201
Medogsfat:The stripes can be done using THIS guys vinyl pinstripes - really good quality graphic stripes. I've used his black ones on CX50's & 100's with good results.
You make me happy Chris! Thanks a lot
Now I can hide those (yellowished) white stripes with these....
Step1
- Joined on 07-06-2008
- Manchester
- Posts 961
Have you thought about trying this stuff for lettering?
http://shop.ebay.co.uk/?_from=R40&_trksid=p3984.m570.l1313&_nkw=Inkjet+Decal+Paper&_sacat=See-All-Categories
You would have to finish off with laquer of some sort!
Medogsfat
- Posts 4,045
Nickyg63:
all done with cleaned frets!
Really really nice job Nick. Cannot beat the professional approach, but you've just GOT to recloth the frets in white though. It does mean painting the frames white/light before you start though or they'll show through unfortunately.
Chris.
Nickyg63
- Joined on 08-28-2007
- Nottingham
- Posts 628
Medogsfat:
Nickyg63:
Chris.
Hi Chris, I did think about white frets but I am not convinced? I have thought about a nice wine red and doing my pentas as well?
I may get shot for this, but has anyone ever seen pentas painted?? I wonder if it makes them look even bigger?
Whats everyones thoughts?
Nickyg63
- Nottingham
- Posts 628
Leslie:
We use a cutting compound at work I bet that would clean up the yellowed stripes! Ask at any bodyshop for a little bit of compound that they will machine polish with, Cheers Nick
Or I can send you some if you wish?
Stonk
- Joined on 04-16-2007
- Marlow, Bucks, UK
- Posts 1,688
Nickyg63:I may get shot for this, but has anyone ever seen pentas painted??
No but THIS thread shows Pentas with white frets and because these cover a vast area of the speaker it might give an indication what they could look like.
If you think nobody cares, try missing a couple of payments.
Nickyg63
- Nottingham
- Posts 628
Stonk:
I think it might look smart painted white?
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Nickyg63:
Stonk:
Not so sure. I remember reading somewhere that one of the ideas behind the design was that the sides should mirror the surroundings, helping the speakers to blend in. It certainly works that way in this doghouse I'm living in.
If painted, I'm afraid they would need a lot of free space around them to look anything but completely odd.
pacificocean
- Joined on 01-19-2011
- Posts 27
Leslie:
Got some excellent cloths in white for you which I bought from Ebay.
Have these also in blue/black/red. If you need for just these 2 speakers I can send them to you for free (together with the MCL2P?
Leslie what does make this cloth so excellent? Is this better then speaker cloth from a local shop or other webshops?
Leslie
- Netherlands
- Posts 2,201
pacificocean:Leslie what does make this cloth so excellent? Is this better then speaker cloth from a local shop or other webshops?
I think because of the pattern and colours and cheap?
pacificocean
- Posts 27
Thanks Leslie. Does this work for Redline speakers as wel? If so which colour to pick? And I do not see the tape in the same shop or did you buy it somewhere els?
Sorry Nickyg63 for stealing your topic. Please let me know when it is bothering you. I will create my own topic then.
Leslie
- Netherlands
- Posts 2,201
pacificocean:
Off course it will work for RL's. Did a few myself and Penta's as well. I "borrowed" tape from my employer . It's very thin and very, very sticky so it works excellent! Colour however is very personal. Sometimes you have to take a challenge to change. I prefer red with white.
Maybe I will try our national Dutch colour Red White and Blue for the CX100 Cool man.....
Leslie
- Netherlands
- Posts 2,201
Did these this evening for my CX100 in red.
h1npw
- A cricket ball throw from Trent Bridge
- Posts 776
Superb photos and superb job Leslie!
Cheers
Nigel
Leslie
- Netherlands
- Posts 2,201
h1npw:
Cheers
Nigel
Thank you Nigel, my only concern were the white stripes on the sides which became yellow (why is that?).
Chris has given me the solution and have ordered a few meters on Ebay.
The red really looks fabulous. The next CK50's or/and 100's will be blue.
So, now refoaming and cloths is so easy to do after lots of failures
Leslie
- Netherlands
- Posts 2,201
Will let you know on Monday okay? Are you from Holland since Praxis and Gamma are typical Dutch DIY stores. I could give you some if it's just for a pair of speakers....
