Latest post 12-14-2011 6:02 PM by Leslie. 71 replies.
Page 2 of 3 (72 items) < Previous 1 2 3 Next >
  • 03-26-2011 1:36 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: cx50 refurb with pictures!
    Leslie:
    What did you do with the B&O text on the front and the stripe on the sides?
    You may be able to reproduce the font with Helvetica Lettraset. Not sure what font size you'd need.
    The stripes can be done using THIS guys vinyl pinstripes - really good quality graphic stripes. I've used his black ones on CX50's & 100's with good results.
    Chris.
  • 03-26-2011 1:47 PM In reply to
    Hi Chris, I had a look at the lettering but its to small for a decal company to make. They could print it on clear! The pinstripe is an option i will have a look into cheers Nick
  • 03-26-2011 1:59 PM In reply to
    all done with cleaned frets!  That little dot on one of the frets isn't a hole its something on the camera lense
  • 03-26-2011 2:25 PM In reply to
    Nickyg63:
    Painted over, I'm afraid!
    Same as mine. Don't have any alternatives fore the text but for the stripes on the side you can use transparent laquer. Just tape the sides off.
    For the black I have been using a sort of glossy tape which they use for making lines on a whiteboard.
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 03-26-2011 5:42 PM In reply to
    Medogsfat:
    Leslie:
    Chris.
    Use Beofont.ttf. search the net or here, I dont remember where but its somewhereBig Smile
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 03-26-2011 5:49 PM In reply to
    Medogsfat:
    You make me happy Chris! Thanks a lotYes -  thumbs up
    Now I can hide those (yellowished) white stripes with these....
  • 03-26-2011 7:01 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Have you thought about trying this stuff for lettering?
    http://shop.ebay.co.uk/?_from=R40&_trksid=p3984.m570.l1313&_nkw=Inkjet+Decal+Paper&_sacat=See-All-Categories
    You would have to finish off with laquer of some sort!
    Olly.
  • 03-26-2011 8:25 PM In reply to
    • Medogsfat
    • Posts 4,045
    Nickyg63:
    Really really nice job Nick. Cannot beat the professional approach, but you've just GOT to recloth the frets in white though. It does mean painting the frames white/light before you start though or they'll show through unfortunately.
    Chris.
  • 03-27-2011 3:05 AM In reply to
    Medogsfat:
    Nickyg63:
    Chris.
    Hi Chris, I did think about white frets but I am not convinced?  I have thought about a nice wine red and doing my pentas as well?
    I may get shot for this, but has anyone ever seen pentas painted??  I wonder if it makes them look even bigger?
    Whats everyones thoughts?
  • 03-27-2011 3:09 AM In reply to
    Leslie:
    Medogsfat:
    We use a cutting compound at work I bet that would clean up the yellowed stripes! Ask at any bodyshop for a little bit of compound that they will machine polish with, Cheers Nick
    Or I can send you some if you wish?
  • 03-27-2011 4:18 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Nickyg63:
    No but THIS thread shows Pentas with white frets and because these cover a vast area of the speaker it might give an indication what they could look like.
    If you think nobody cares, try missing a couple of payments.
  • 03-27-2011 4:25 AM In reply to
    Stonk:
    Nickyg63:
    I think it might look smart painted white?
  • 03-27-2011 12:02 PM In reply to
    Nickyg63:
    Stonk:
    Nickyg63:
    Not so sure. I remember reading somewhere that one of the ideas behind the design was that the sides should mirror the surroundings, helping the speakers to blend in. It certainly works that way in this doghouse I'm living in.
    If painted, I'm afraid they would need a lot of free space around them to look anything but completely odd.
    -mika
  • 03-27-2011 12:20 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    I like the white covers I think, but I would not touch the sides personally and I like white! Of course it is a taste and / or an evironment thing.
    Olly.
  • 03-27-2011 4:28 PM In reply to
    Re: cx50 refurb
    Leslie:
    Got some excellent cloths in white for you which I bought from Ebay.
    Have these also in blue/black/red. If you need for just these 2 speakers I can send them to you for free (together with the MCL2P?Smile
    Leslie what does make this cloth so excellent? Is this better then speaker cloth from a local shop or other webshops?
  • 03-27-2011 4:39 PM In reply to
    Re: cx50 refurb
    The more I look at my pentas the more I think that they should stay as they are!  I think the frets will look good but keep the steel I say!
  • 03-27-2011 5:00 PM In reply to
    Re: cx50 refurb
    pacificocean:
    I think because of the pattern and colours and cheap?
  • 03-27-2011 5:19 PM In reply to
    Re: cx50 refurb
    Thanks Leslie. Does this work for Redline speakers as wel? If so which colour to pick? And I do not see the tape in the same shop or did you buy it somewhere els?
    Sorry Nickyg63 for stealing your topic. Please let me know when it is bothering you.  I will create my own topic then.
  • 03-27-2011 5:44 PM In reply to
    Re: cx50 refurb
    pacificocean:
    Off course it will work for RL's. Did a few myself and Penta's as well. I "borrowed" tape from my employerEmbarrassed. It's very thin and very, very sticky so it works excellent! Colour however is very personal. Sometimes you have to take a challenge to change. I prefer red with white.
    Maybe I will try our national Dutch colour Red White and Blue for the CX100Cool Cool man.....
  • 03-28-2011 6:14 PM In reply to
    Re: cx50 refurb
    Did these this evening for my CX100 in red.
  • 03-29-2011 1:21 PM In reply to
    • h1npw
    • A cricket ball throw from Trent Bridge
    • Posts 776
    Re: cx50 refurb
    Superb photos and superb job Leslie!
    Cheers
    Nigel
  • 03-29-2011 1:45 PM In reply to
    Re: cx50 refurb
    h1npw:
    Cheers
    Nigel
    Thank you Nigel, my only concern were the white stripes on the sides which became yellow (why is that?).
    Chris has given me the solution and have ordered a few meters on Ebay.
    The red really looks fabulous. The next CK50's or/and 100's will be blue.
    So, now refoaming and cloths is so easy to doWhistle after lots of failures Super Angry
  • 03-29-2011 5:13 PM In reply to
    • jahur
    • Top 500 Contributor
    • Joined on 02-07-2011
    • planet zonk
    • Posts 161
    Re: cx50 refurb
    they look stunning, i had a set of these with white frets, i purchased from bang and olufsen of willen some years ago, i put the frets into soak with silk washing solution and they came up a treat. i used autoglym wax for the cabinets. superb!
    (formerly nokinnikon from the old site)
  • 09-17-2011 5:35 PM In reply to
    Re: cx50 refurb
    Leslie, Can you specify the Tesa tape your using? Do you have a type number or name? I was not able to find such tape at Gamma or Praxis etc. Maybe I am able to find it somewhere else with more spedific information.
  • 09-17-2011 5:44 PM In reply to
    Re: cx50 refurb
    Will let you know on Monday okay? Are you from Holland since Praxis and Gamma are typical Dutch DIY stores. I could give you some if it's just for a pair of speakers....
