I have a Beosystem 5500 + Beocord 6500 + the Master Control Unit.
Having finally decided to retrieve these items and set them up once again, not all is well.
Both the Beogram and Radio on the Beomaster perform with no problems, volume adjusts properly and all dials etc light-up. However both the tape recorder and CD player have the same problem, namely:
output level lights are on and move with the music, the tape advances and I presume that the CD also, but no sound whatsoever: as the other sources do produce sound I suppose it is not the mute button.
At this point I should mention that I am outputting to another amp from the pre-amp phono outlets on the Beomaster as I no longer have suitable loudspeakers.
Any ideas would be welcome.
Thanks. BTW a great site that I have only just found since experiencing this problem.
