Latest post 03-03-2011 4:43 PM by OKF. 2 replies.
Page 1 of 1 (3 items)
  • 03-01-2011 5:55 PM
    • OKF
    • Top 500 Contributor
    • Joined on 02-22-2008
    • Posts 204
    BV 10-40 with BC2 settings unclear to program
    Hi
    I have looked at programming the Beo 5 for the following setup and some questions do arise from that (I am in Germany)
    My components are/will be: BV10-40 with DVB-HD T/C/S2 Module (1846895), BC2 (it is I think MK1), IPORT FS-23 (B+O calls it System Dock) Apple TV plus link rooms with Beo Passive and another room fully equipped but not important for this here:
    1. There are 2 TV's as a choice, the 'BV-10-40 PUC' and the 'BV-10-40'. When I choose the PUC one Iget CAMERA installed so I assume 'BV-10-40' is the right one to implement?
    2. When I choose the 'BV-10-40' under the TV and the selected product data I get under ...
    -MODULES:
    --DVB-HD EU as TV
    --DVB-HD EU as DTV
    --DVB-HD D. CH. A (Multifeed) as TV
    --DVB-HD D. CH. A (Multifeed) as DTV
    --Use TV and DTV for ext. sources
    Do thise settings refer to the DVB-HD T/C/S2 Module (1846895) or do I have to choose some other setting or do I need another XML-File for the DVB-HD T/C/S2 Module?
    Then it also says
    -NAVIGATION BUTTONS
    --no Navigation Button
    --Navigation Button - Mode 1
    --Navigation Button - Mode 2
    What is this? What does it refer to? Which to set?
    3. When it comes to the BC2 I can choose that under AUDIO SYSTEM but further down in the Menue I can choose this under the DVD section which means it creates a DVD2 in the Beo5. I assume it is right just to add the BC2 from th AUDIO section?
    4. When I choose the Apple Remote for the ATV under 'PUC' it does not really produce any buttons on the Beo 5 aprt from MENUE. Is this standard? The XML-File is named 'Apple_STB_Apple-Remote_V02,00a' (under STB, PUC SOURCES)
    Okay, I think that is it. I would appreciate some answers and then I am set.
    Best regards Oliver
  • 03-03-2011 2:58 PM In reply to
    Re: BV 10-40 with BC2 settings unclear to program
    OKF:
    Hi
    -MODULES:
    --DVB-HD EU as TV
    --DVB-HD EU as DTV
    Then it also says
    -NAVIGATION BUTTONS
    That's a start for you
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
  • 03-03-2011 4:43 PM In reply to
    • OKF
    • Posts 204
    Thanks, but BV10-40-PUC should be wrong...see my comment....so it does not help at all
    Best regards Oliver
