Hi
I have looked at programming the Beo 5 for the following setup and some questions do arise from that (I am in Germany)
My components are/will be: BV10-40 with DVB-HD T/C/S2 Module (1846895), BC2 (it is I think MK1), IPORT FS-23 (B+O calls it System Dock) Apple TV plus link rooms with Beo Passive and another room fully equipped but not important for this here:
1. There are 2 TV's as a choice, the 'BV-10-40 PUC' and the 'BV-10-40'. When I choose the PUC one Iget CAMERA installed so I assume 'BV-10-40' is the right one to implement?
2. When I choose the 'BV-10-40' under the TV and the selected product data I get under ...
-MODULES:
--DVB-HD EU as TV
--DVB-HD EU as DTV
--DVB-HD D. CH. A (Multifeed) as TV
--DVB-HD D. CH. A (Multifeed) as DTV
--Use TV and DTV for ext. sources
Do thise settings refer to the DVB-HD T/C/S2 Module (1846895) or do I have to choose some other setting or do I need another XML-File for the DVB-HD T/C/S2 Module?
Then it also says
-NAVIGATION BUTTONS
--no Navigation Button
--Navigation Button - Mode 1
--Navigation Button - Mode 2
What is this? What does it refer to? Which to set?
3. When it comes to the BC2 I can choose that under AUDIO SYSTEM but further down in the Menue I can choose this under the DVD section which means it creates a DVD2 in the Beo5. I assume it is right just to add the BC2 from th AUDIO section?
4. When I choose the Apple Remote for the ATV under 'PUC' it does not really produce any buttons on the Beo 5 aprt from MENUE. Is this standard? The XML-File is named 'Apple_STB_Apple-Remote_V02,00a' (under STB, PUC SOURCES)
Okay, I think that is it. I would appreciate some answers and then I am set.
