Latest post 02-24-2011 2:42 PM by Doctor. 1 replies.
Page 1 of 1 (2 items)
  • 02-24-2011 12:35 PM
    BEOLAB 3000 PROBLEMS....HELP.....
    Hello  Members,
       Have a nice pair of Beolab 3000. Two problems.....upon turn on there is a power spike noise. Does not do it everytime. The 2nd is after using the mute on and then off my beocenter 9000.....the beolabs will have like a static noise  in the back round...it too is does not to it everytime the mute is used on the 9000. I have use other speakers from 9000 .....no problem there with any noise from the receiver with the mute....So it appears to be in the amplifiers of the beolab 3000....has anybody had this type of problems with the beolab 3000???? Thanks for any info you can share.
        Don
        USA
  • 02-24-2011 2:42 PM In reply to
    Re: BEOLAB 3000 PROBLEMS....HELP.....
    There is a noted fault that if the wire bundle to the display is too close to some of the modules, you can get an intermittent hum in the speakers. Is it both speakers or just the one?
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
