Hello Members,
Have a nice pair of Beolab 3000. Two problems.....upon turn on there is a power spike noise. Does not do it everytime. The 2nd is after using the mute on and then off my beocenter 9000.....the beolabs will have like a static noise in the back round...it too is does not to it everytime the mute is used on the 9000. I have use other speakers from 9000 .....no problem there with any noise from the receiver with the mute....So it appears to be in the amplifiers of the beolab 3000....has anybody had this type of problems with the beolab 3000???? Thanks for any info you can share.
Don
USA
