Hi all,
Those of you with a BeoMaster 1600 could really help me!
In the attached pic, is a gray wire with a red stripe. It is a co-axial wire. It's under the Tuning capacitor.
The internal conductor was not connected anywhere, and the external sheath is grounded. It's other end becomes a yellow wire (gelb in the Service Manual), and goes to the 4 FM preset buttons.
Anyway, I connected it to where I thought it should be, as there was a big glob of solder, but it's not the correct place - the preset voltages are all over the place.
The SM I have, does not show a coax wire connected in this area, so if anyone with one of these could have a look inside his unit, and photograph the correct place to connect the internal conductor, it would really help me.
Menahem
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
