Latest post 02-03-2011 2:00 AM by yachadm. 2 replies.
Page 1 of 1 (3 items)
  • 02-02-2011 12:07 PM
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    BeoMaster 1600 (Type 2113) wiring problem
    Hi all,
    Those of you with a BeoMaster 1600 could really help me!
    In the attached pic, is a gray wire with a red stripe. It is a co-axial wire. It's under the Tuning capacitor.
    The internal conductor was not connected anywhere, and the external sheath is grounded. It's other end becomes a yellow wire (gelb in the Service Manual), and goes to the 4 FM preset buttons.
    Anyway, I connected it to where I thought it should be, as there was a big glob of solder, but it's not the correct place - the preset voltages are all over the place.
    The SM I have, does not show a coax wire connected in this area, so if anyone with one of these could have a look inside his unit, and photograph the correct place to connect the internal conductor, it would really help me.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 02-02-2011 3:32 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: BeoMaster 1600 (Type 2113) wiring problem
    I seem to remember there are two slightly different
    versions of the Beomaster 1600 chassis.
    However, in the one shown here, that shielded lead goes to a
    tag on the potentiometer, it may be the same in your BM:
  • 02-03-2011 2:00 AM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    Thank you!
    That is the correct connection. All Preset voltages normal now!
    Menahem
