Latest post 07-31-2007 11:54 AM by The Stig - ver. 1.7. 4 replies.
Page 1 of 1 (5 items)
  • 07-03-2007 12:28 PM
    • Chris
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Bredene near Ostend-Belgium
    • Posts 143
    Beolink Passive question
    I have a question about the controls of a Beolink Passive.
    With the Beo4 it is possible to adjust balance, bass, treble and loudness individually, but in how many steps upwards or onwards? I would like to get it again in flat response for the tonal controls.
    Yes, I kown my spelling is horrible… Huh?
  • 07-04-2007 8:15 AM In reply to
    Re: Beolink Passive question
    Yes, add A.SETUP to you Beo4 list function and away you go.  Pressing GO when selected will take you through the options.
  • 07-04-2007 12:03 PM In reply to
    • Chris
    • Posts 143
    meandmyshadow:
    Hi meandmyshadow,
    Thanks for the response, but that was not the question.
    I now perfectly well how to handle A.setup for tonal and balance controls. It is about how do I put the Beolink Passive back to flat sound controls.
    For example, in how many steps (pushes on the remote) is treble set at maximum from flat sound ( 5 up for max. treble?).
    By a Beosound you have a visual look (+1,+2,....) to put controls up, but not on the Passive. Only your ears can hear the difference.
  • 07-31-2007 2:52 AM In reply to
    This is an interesting question and seems to have been passed over by the great and the good on BeoWorld.
    Just how do you return a passive to flat tone response?
    Does it reset to flat every time you power on and remember your settings when on standby?
    I don't have a system to try so anybody????
    Regards Graham
  • 07-31-2007 11:54 AM In reply to
    Hi
    I thing it's +3 and -3 because it  regulates +/- 9 dB at max...
