meandmyshadow:Yes, add A.SETUP to you Beo4 list function and away you go.  Pressing GO when selected will take you through the options.
Hi meandmyshadow,
Thanks for the response, but that was not the question.
I now perfectly well how to handle A.setup for tonal and balance controls. It is about how do I put the Beolink Passive back to flat sound controls.
For example, in how many steps (pushes on the remote) is  treble set at maximum from flat sound ( 5 up for max. treble?).
By a Beosound you have a visual look (+1,+2,....) to put controls up, but not on the Passive. Only your ears can hear the difference.
									    Yes, I kown my spelling is horrible…
