Latest post 02-01-2011 11:06 AM by beopaul. 11 replies.
Page 1 of 1 (12 items)
  • 01-27-2011 7:45 AM
    BeoLab Penta1 Stupid Question from Newbie
    Hi--I just got a pair of BeoLab Penta 1's complete with BeoCenter9000
    Hooked up it reads on the speakers the CD output but no sound.
    Other problem is I would like to use them as front speakers in HT system
    Hooked up line out from Denon3802 receiver and plugged in the speakers
    again NO Sound.
    ---Third try decided to bypass the built in Amps and ran speaker wire
    from the Internal banana plugs to HK2.1 signature amp---
    result No Sound.
    What am I doing Wrong are these worth repairing????
    Can I when repaired just use the Penta's in a Home Theatre setup
    as mono block amps and just run a signal from the receiver????
    Is this possible????----and will it sound good as the fronts in a Home
    theatre system?????
    ----Electronics Status-----beginner.
    Pls help if you have the patience and time to answer what I realize
    probably aren't to bright questions.
    thanks
  • 01-27-2011 12:00 PM In reply to
    Re: BeoLab Penta1 Stupid Question from Newbie
    Under the amp section there should be a switch which you can switch dependant on the source (TV or audio).  Try that.  Do the amp power lights change from red/orange to green when they are switched on?
    Am I ready? I was born ready!
  • 01-27-2011 1:15 PM In reply to
    They are amazing speakers, I cant understand why you have no sound at all do they lights on the amps change to green??  It sounds like its something in the speaker unit?? Cheers Nick
  • 01-28-2011 1:32 AM In reply to
    BeoLab Penta Mk. 1.          3 polet DIN stik for lyd & display.
    BeoLab Penta 1
    http://www.hifi4all.dk/forum/forum_posts.asp?TID=32157&PN=0&TPN=4
    Unfortunately, I write only Danish / Peter Pan
  • 01-28-2011 8:48 PM In reply to
    Thanks for all your help.
    Right now I have them passively amped.
    I ran speaker wires from the upper internal
    banana plugs to my HK2.1 signature and I'm happy to report although no display
    they sound great.
    Does this mean I can also get the displays
    working on a Denon Receiver?
    Thanks for all the info.
    Even if they end up staying passively amped they are keepers.
    I traded a DAC for them so I'm happy.
    lefty11
  • 01-29-2011 3:17 AM In reply to
    No, the displays will only work with a suitable B&O Beomaster or Beocenter amplifier.
    Regards Graham
  • 01-29-2011 3:38 AM In reply to
    I also got a beocenter9000 and a
    remote1000 with the package---the displays do work using that but as I want them for fronts in my HT/Stereo guess I will
    live without the displays.
    Question
    The beocenter9000 cassette tape door won't open is there a manual override to
    get it open???
    The CD load door works fine and also the
    amp is fine as it plays CDs flawlessly.
    Tape door isn't a big issue unless easy fix
    as I don't need it to play tapes anyway.
    I'm still stoked my trade was
    Beresford 7520DAC in return I got
    BeoLab Penta Mrk1's
    BeoCenter9000
    BeoRemote1000
    After hearing the Penta's I would make this
    deal all day long----they are just gorgeous
    no dings and one little pull in the grill cover
    you can't find unless you know where it is.
    My first experience with B&O and I guess
    I'm on my way to being converted.
    Lefty11
  • 01-29-2011 6:45 AM In reply to
    Hi Lefty11
    Its easy to like the Penta´s :D
    If you dont want to use a Bang-amp (first choice with 4-pin special DIN as seen on pic above) then I would use Line INPUT from your pre-amp/line out connection on your amp. There will be no info on displays tho but personally I think that is the best way.
    The Tape-door shouldnt be that hard to fix, should prob be hard and old "lubrication". Try search here on the forum coz I have seen some posts on similar problems on BC9000/9500/9300.
    Cheers
    Jesper
    Sweden
  • 01-29-2011 11:28 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Out of interest what did you think of B&O before you did this deal??
    Olly.
  • 01-30-2011 4:21 AM In reply to
    Before I did the deal B&O wasn't even on
    my radar!!!!! Was just kinda looking for
    some good front speakers for music and
    home theatre about 50/50.
    I can tell you even passively amped I'm
    very happy with them in both venue's
    We watched Inception tonight and the
    Penta's did it proud.
    Also the WAF (wife approval factor) is very
    high on these even though they're over
    twenty years old. I never imagined I would
    get away with big speakers in the front but
    these seem to have a timeless style in
    my opinion and obviously in the little ladies
    as well!!!!!
    Life is good!!!!
    Lefty11
  • 01-31-2011 4:28 PM In reply to
    Check your mids! Most likely your mids suffer with foamrot if they aren't replaced!
    All the penta's mk I, II and early III's will suffer with foamrot.
    BTW: only the mkIII has a switch on the bottom to switch between an audiomaster or videomaster.
  • 02-01-2011 11:06 AM In reply to
    Beobuddy:
    Actually, mkII has the switch as well.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
