Latest post 01-16-2011 2:48 PM by waxer. 4 replies.
Page 1 of 1 (5 items)
  • 01-15-2011 11:52 PM
    • waxer
    • Not Ranked
    • Joined on 08-19-2007
    • Posts 6
    Beovox cx1000
    Hi, i need to replace the woofers in my Beovox CX100's, the foam is shot.  is it possible to just get a matching cone and replace it, and where could i get the info to do so? any preferred brands that will give the quality sound?  any help much appreciated
  • 01-16-2011 12:50 AM In reply to
    Re: Beovox cx1000
    Never heard of CX 1000, but if you mean CX 100 try here.
    http://forum.beoworld.org/forums/p/37357/310007.aspx#310007
    Measure your surrounds, order more than you need, check the forum on how to, and dont forget to change caps in your crossovers.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 01-16-2011 3:30 AM In reply to
    Re: Beovox cx1000
    This thread is from a member that was was refoaming his CX50s and 100s and shared his experience and was kind enough to write a brief guide.
    http://forum.beoworld.org/forums/t/36917.aspx
    Beosystem 7000/6500- Beolab 4000 - Beosound 1 - A8 - Earset 3 - Beo4
  • 01-16-2011 7:14 AM In reply to
    Re: Beovox cx1000
    waxer:
    Replacement cones are not necessary.
    Just buy some new foam rings from Good HiFi (based in Netherlands), they send you the required glue with brush applicator (similar to a Tippex bottle), all for just a few quid. Find them listing on ebay or google 'good hi fi'
    Remove the frets from the speaker, clean off the old rotten foams, then relace with the new ones, applying the glue to both surfaces (around the ring edge and around the cone edge). Find a glass or cup with the correct size rim to use as a weight to press the new foams down and ensure the glue bonds nicely.
    You dont even need to remove the cones from the CX100 housing. I did a pair a few months ago, cones in situ. They play like new now.
    I think Good HiFi have posted a video on their site demonstrating someone replacing a foam ring.
    Regards.
    Michael
    BV5, BV Avant, MX4000, MX1500
    BS 7000, BS 5500
    Penta III, Penta II, BL 4000, RL 60.2,  RL 35, CX-100 Alu
    BL 7000, MCP6500, MCP5500,  BL 5000,  Beo4 (x2), BL 1000 (x2)
  • 01-16-2011 2:48 PM In reply to
    • waxer
    • Not Ranked
    • Posts 6
    Re: Beovox cx1000
    too many 0's.  many thanks.  cheers
