waxer:
Hi, i need to replace the woofers in my Beovox CX100's, the foam is shot. is it possible to just get a matching cone and replace it, and where could i get the info to do so? any preferred brands that will give the quality sound? any help much appreciated
Replacement cones are not necessary.
Just buy some new foam rings from Good HiFi (based in Netherlands), they send you the required glue with brush applicator (similar to a Tippex bottle), all for just a few quid. Find them listing on ebay or google 'good hi fi'
Remove the frets from the speaker, clean off the old rotten foams, then relace with the new ones, applying the glue to both surfaces (around the ring edge and around the cone edge). Find a glass or cup with the correct size rim to use as a weight to press the new foams down and ensure the glue bonds nicely.
You dont even need to remove the cones from the CX100 housing. I did a pair a few months ago, cones in situ. They play like new now.
I think Good HiFi have posted a video on their site demonstrating someone replacing a foam ring.
Regards.
Michael
BV5, BV Avant, MX4000, MX1500
BS 7000, BS 5500
Penta III, Penta II, BL 4000, RL 60.2, RL 35, CX-100 Alu
BL 7000, MCP6500, MCP5500, BL 5000, Beo4 (x2), BL 1000 (x2)
