Hi all,
being able to install both, the BeoCenter2 as well as the BeoSound 9000 at home my BeoDealer told me that it is not possible to install 2 audiomaster in one masterlink installation. But he told that they are going to search for a solution.
As I do not want to store or sell one of both devices I am searching for a possibility to install both in one masterlink. Might it be possible to
- customize the BeoCenter2 in a way that it does not react on the CD specific commands
- use a BEO5 /6 to switch scenarios a) BeoCenter2 active, b) BeoSound 9000 active
Thank you for any hint or suggestion.
Cheers,
Beo Time, A8, EarSet3i, EarSet2, BC2, BC6, BL3, BL11, Apple TV1, BEO Ballpen, BL2000, BL3500
Christmas 2010 Prize Draw 1st winner. BeoSound 9000 Mk3
Thank you
