Latest post 01-11-2011 9:58 AM by Large48. 4 replies.
Page 1 of 1 (5 items)
  • 01-11-2011 5:50 AM
    2 audiomaster in one Masterlink installation
    Hi all,
    being able to install both, the BeoCenter2 as well as the BeoSound 9000 at home my BeoDealer told me that it is not possible to install 2 audiomaster in one masterlink installation. But he told that they are going to search for a solution.
    As I do not want to store or sell one of both devices I am searching for a possibility to install both in one masterlink. Might it be possible to
    - customize the BeoCenter2 in a way that it does not react on the CD specific commands
    - use a BEO5 /6 to switch scenarios a) BeoCenter2 active, b) BeoSound 9000 active
    Thank you for any hint or suggestion.
    Cheers,
    Beo Time, A8, EarSet3i, EarSet2, BC2, BC6, BL3, BL11, Apple TV1, BEO Ballpen, BL2000, BL3500
    Christmas 2010 Prize Draw 1st winner. BeoSound 9000 Mk3
    Thank you
  • 01-11-2011 8:28 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: 2 audiomaster in one Masterlink installation
    Hi
    It IS possible to have both of these units in the same Masterlink set up, assuming that they are in different rooms. What is NOT possible is to configure them both as the audio master.
    One can be in option1 and feed the main room and the link system.
    The other can be in option4 and its sources are only available in the link room. It is still possible to access sources from the main room audio master.
    Option4 is only available to products above a certain software level.
    Regards
    Opman
  • 01-11-2011 8:33 AM In reply to
    • Opman
    • Cheshire, UK
    • Posts 323
    Just has another thought.
    You may be able to place BeoCenter2 in the main room was well as BeoSound9000 but not connect Masterlink to the socket box. By connecting a scart lead to the television you could simply use BeoCenter2 as a DVD player. This way there wouldn't be an option programme clash. Although it would be a fairly expensive SD DVD player.
    Opman
  • 01-11-2011 9:43 AM In reply to
    Hi Opman,
    Thank you very much for the fast reply. Sounds like I am going for a super stylish DVD Player Cool
    Cheers,
    Thank you
  • 01-11-2011 9:58 AM In reply to
    Or, you could (like I do) only have the one you want to use powered on at any one time.............
    Not ideal but works perfectly! :-)
    Train Hard - Run Fast - Hit to Kill!!!
