Latest post 01-01-2011 2:49 PM by Craig. 2 replies.
Page 1 of 1 (3 items)
  • 01-01-2011 1:47 PM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Beolink 1000 strange probelm
    Having some problems with a MK4 BL1000. All of a sudden the volume will just go up on ity's own. It's not when I have used it and the button is sticking. It just happens. All I can do to stop it is remove the batteries. Sometimes it can take 5 mins for it to happen. other times it can be hours. It has had a new rubber keypad fitted, but I can't see this been the problem. When it's not turning itself up, the volume buttons work perfectly. any ideas appreciated.
    CraigSmile
  • 01-01-2011 2:28 PM In reply to
    Re: Beolink 1000 strange probelm
    Sounds like the actual circuit board (or the contact foil) need cleaning. Could be corrosion from a leaked battery or finger grease oozed through the rubber mat Ick!
    -mika
  • 01-01-2011 2:49 PM In reply to
    • Craig
    • Posts 4,855
    tournedos:
    Ill get it apart and see what it's like. Seen some that are really nasty inside.Ick!
    CraigSmile
