Latest post 12-30-2010 10:07 AM by Dillen. 1 replies.
Page 1 of 1 (2 items)
  • 12-27-2010 7:11 AM
    • jl13
    • Not Ranked
    • Joined on 10-17-2010
    • Posts 8
    right model of k7 deck in beocenter 9500
    well I'm a little bit confused with the cassette deck of my beocenter 9500. Always thought it was fitted with the same model than the bc 9000, but without the 3 motors, but keeping the dolby b and c. Right ?
    As my k7 deck was faulty, I jump on another one coming from a bc9500 I bought for 50 €. But I can't believe my eyes when it appeared to be the same model than a bc 9000 !
    As my beocenter 9500 is among the last ones, it seems than my k7 is the same than the becenter 2500 one !
    Is anybody who could confirm this, as I'm looking for a working k7 deck, and i don't want to buy another wrong one!!
    Thank you very much
  • 12-30-2010 10:07 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: right model of k7 deck in beocenter 9500
    It seems that the two tapedeck versions are generally found
    in all of the autoreverse machines.
    Most problems with these decks are worn belts (available from me) and
    mis-aligned brakes (repairable).
