Latest post 12-21-2010 3:47 AM by dannybates. 8 replies.
Page 1 of 1 (9 items)
  • 12-20-2010 8:21 AM
    Beovision 6
    Hi could someone help with how to access the service counter on my new(second hand) beovision 6?
    Filed under:
  • 12-20-2010 10:05 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: Beovision 6
    When it asks for the PIN CODE press and hold << for 3 seconds
    The Master code menu appears
    Enter the service Code 11111
    NOTE Be very careful in there. You can seriously ruin your TV if you don't know what you're doing.
    SteveSmile
    If you think nobody cares, try missing a couple of payments.
  • 12-20-2010 10:50 AM In reply to
    Re: Beovision 6
    Thanks Steve.Tried that but it wont accept 11111 as the Mastercode.Should i try the existing Pin?Danny
  • 12-20-2010 11:50 AM In reply to
    • Stonk
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: Beovision 6
    That was for the BV6 26 If you have the 22" enter the setup menu and press 0, 0, Go within 3 seconds
  • 12-20-2010 12:03 PM In reply to
    Re: Beovision 6
    it is the bv6 26.When ienter11111 in the mastercode menu it just comes up 'pincode error'.D.
  • 12-20-2010 12:11 PM In reply to
    • Stonk
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: Beovision 6
    Oh Unsure
    Have you tried the 22" method?
    the 11111 code is from the 26" service manual.
  • 12-20-2010 12:31 PM In reply to
    Re: Beovision 6
    Have now-that worked a treat-its definately the 26" in case you thought i,m being a chump!The service counter came up
       audio(days)212
      Boot counter 109
      Video(days)745
    on(T*10)507
    What Does this mean? Thanks for your help,Danny
  • 12-21-2010 2:35 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: Beovision 6
    These service counters will add up the hours the set has been in use, and give the results in days. Your set was turned on 507 x 10 times, and has been used for audio only (screen off) for a total of 212 days and for video for a total of 745 days. If you add audio & video time, it's been turned on for a total of 2.6 years. Pretty high milage.
    Roger
  • 12-21-2010 3:47 AM In reply to
    Re: Beovision 6
    Thanks Roger,that makes sense-good job i only gave £250 for it! Danny
