Latest post 12-17-2010 11:26 AM by Dillen. 2 replies.
Page 1 of 1 (3 items)
  • 12-17-2010 11:06 AM
    BEOCORD 2000 - Reel to Reel Tape Recorder
    I am looking for a mains connecting lead to connect a Beocord 2000 to the mains. It is the plug which connects to the equipment which is the problem as these plugs do not seem to be made anymore. Ray Morris
  • 12-17-2010 11:22 AM In reply to
    Re: BEOCORD 2000 - Reel to Reel Tape Recorder
    Not 100% certain, but look for NAIM or QUAD, perhaps REVOX leads... I *think* they are the same.
    • B&o bottle opener
  • 12-17-2010 11:26 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    You already asked the same once - and received a similar answer:
    http://forum.beoworld.org/forums/p/36758/304652.aspx
    I doubt you will find an original cable that is still safe to use.
