I am looking for a mains connecting lead to connect a Beocord 2000 to the mains. It is the plug which connects to the equipment which is the problem as these plugs do not seem to be made anymore. Ray Morris
Not 100% certain, but look for NAIM or QUAD, perhaps REVOX leads... I *think* they are the same.
You already asked the same once - and received a similar answer:http://forum.beoworld.org/forums/p/36758/304652.aspx
I doubt you will find an original cable that is still safe to use.
