Latest post 12-17-2010 10:45 AM by hemenex. 7 replies.
Page 1 of 1 (8 items)
  • 12-16-2010 7:56 PM
    Is it possible to set options with Beolink 5000?
    Is it possible to set/change the options for ie the BS9000 with the Beolink 5000 remote?
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 12-16-2010 8:01 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Is it possible to set options with Beolink 5000?
    if BL 5000 is in ONE WAY MODE - yes!
    e.g. "SOUND" "1" "STORE" >>  A.Opt 1
    (same sequence as for a BL1000)
  • 12-17-2010 4:00 AM In reply to
    Same question for BL7000 ?
    As "sound" on BL7000 is not lit during standby
    thx,
      hx
  • 12-17-2010 4:59 AM In reply to
    hemenex:
    Yes - it's so obvious that I had to read the manual to find it Laughing
    PANEL -> SETUP -> SYSTEM -> OPTIONS, then just key in what you'd expect. There's no feedback from the BL7000 so it appears to not work, but you'll see the other kit respond just as it would with a BL1000.
    -mika
  • 12-17-2010 5:11 AM In reply to
    • Vienna
    • Posts 712
    Smile to the best of my remembrance ...
    panel > setup > system > components  > select either "Audio" or " Video" >  and
    the display of the BL7000 will tell you something like
    "face your audio(video)master , list your sources and store"
    This should set the remote to "one way" or "two way" mode.
    then "go-back"
    > options  >  numbers will be displayed >  ...
  • 12-17-2010 9:12 AM In reply to
    Thank you both, works! (Master has to be in stand-by as usual...)
    I had set the option before through a BL1000 but was curious about the BL7000' ability to do this.
    Stepping through all the options I already found the Panel setup but that looked like the audio master's 1 / 2-way setting by learning from the master. 2-way was working already but option 0 / 1 / 2 had to be set.
    Option setting works here even in 2-way mode.
    Being hardware / software engineer & not finding this makes me a bit embarrassed Embarrassed
    Best regards,
      Gunther
  • 12-17-2010 10:14 AM In reply to
    • Vienna
    • Posts 712
    hemenex:
    Smile  ... one never ceases to learn ...
  • 12-17-2010 10:45 AM In reply to
    ... and having found the BL7000 manual: reading manuals sometimes DOES help Stick out tongue
        Gunther
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
