Latest post 09-08-2007 7:27 PM by Peter Pan. 15 replies.
Page 1 of 1 (16 items)
  • 07-01-2007 9:53 AM
    • Beolab
    • Top 150 Contributor
    • Joined on 05-18-2007
    • Sweden
    • Posts 535
    Powerlink MK II vs MK III ??
    Is it typed MK II or MK III on the different PL kables, or how can i see the difference ?
    (I need the MK III)
    Quick answer please!
    Best regards Fredrik L.
    BL8000 MkII Black
  • 07-01-2007 10:00 AM In reply to
    Re: Powerlink MK II vs MK III ??
    Mk3 have a small triangle moulded on the plugs
    Regards Graham
  • 07-01-2007 10:07 AM In reply to
    • Beolab
    • Sweden
    • Posts 535
    joeyboygolf:
    Thats all? No thicker than the mk II then? Just a small triangel?
     Regards
    BL8000 MkII Black
  • 07-01-2007 10:23 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Mk2 is a lot thicker than Mk1 and Mk3.  Mk1 is thin with no triangle on the plugs end, Mk3 is thin with a triangle on the plug end, and Mk2 has no triangle but is almost twice as thick as Mk1 and Mk3.
    Confused?
    Laughing
  • 07-01-2007 10:32 AM In reply to
    MK1 is the original thin cable with blue, green and yellow strands which was supplied with most Active speakers.
    MK2 cable is thicker as it has all 8 pins connected.  This was used for the original active speakers that had displays such as PentaLab.
    MK3 (with the triangle) is not as thick as fully wired Poewrlink.  It has an extra earth cable (blue).  Some of the newer active speakers such as BeoLab3 need this extra earth or they buzz.
    BeoManc.
  • 07-01-2007 10:57 AM In reply to
    • symmes
    • Top 200 Contributor
    • Joined on 04-21-2007
    • Freedonia
    • Posts 290
    Thanks for the explanation.  Can you add how IR cable/pin layout is different from powerlink? Thanks.  Ray
  • 07-01-2007 11:05 AM In reply to
    its a tricky one to describe without you having both in your hands, i ended up buying both types even with the above info, now i know by just looking as ive seen each so many times, im hoping these photos help in the same way
    i cant guarantee they come out actual size but it may help
    p.s im not sure the small triangle thing is true every time, my mark3 dont have any
    jayBig Smile
    oh before i forget, the thinner one is mk3 and the thicker is mk2
    jason
  • 07-01-2007 11:08 AM In reply to
    Have a look at a previous thread on the subject HERE
    Regards Keith....
  • 07-01-2007 12:36 PM In reply to
    Link:  DIN kabler.
    Regards Peter Pan
    Sorry I can not write English.
  • 07-01-2007 12:39 PM In reply to
    Hi Ray,
    are you looking for something like this http://www.beoworld.org/beotech/ir_eye_wiring.htm ?
    There are however different IR eyes available, others only have 5 connectors inside. And the IR connector of a Beolink Passive is a DIN connector and also carries signals for the LEDs and the buttons of the IR eye. This connector also carries power supply for the IR eye. It´s totally different from a powerlink connector!
    Hagen
  • 07-01-2007 4:34 PM In reply to
    • symmes
    • Freedonia
    • Posts 290
    Thanks for that answer and for this thread.  Very beneficial.  When I become emperor, everything will be plug and play, and with one single-strand cable.
    Ray
  • 07-01-2007 10:00 PM In reply to
    • Beolab
    • Sweden
    • Posts 535
    1.Beolab A/B powered speakers= Powerlink MK I, MK II, MKIII  will work fine then?
    2.And Beolab Ice-powered speakers= just Powerlink MK III nothing else!
    3.Powerlink MK II= Is the same as "Fully loaded" powerlink?
    4.But the MKIII for BL A/B powered speaker would sound greater because the extra blue grondwire? Less distortion and pink nois?
    BL8000 MkII Black
  • 09-08-2007 6:28 PM In reply to
    Powerlink MK III
    PowerLink MK III. Cable connection.
    Print billedet ud, det er en stor hjælp når du står med loddekolben.
  • 09-08-2007 6:43 PM In reply to
    Re: Powerlink MK III
    Mk II powerlink can be used with all speakers, Ice power, class A/B, Display or no Display it will work just fine Smile
  • 09-08-2007 7:21 PM In reply to
    Here i have used  PowerLink MK II direct to XLR.
    PowerLink tilsluttet direkte til XLR.
    Mvh Peter Pan
  • 09-08-2007 7:27 PM In reply to
    Her er 0 leder og skærm loddet sammen på RCA bøsningen.
    Det mangler nogle forklaringer, find dem her.
    http://peecee.dk/uploads/0107/mit-icepower500asp-datasheeet. pdf
    Her finder man også:
    ICEpower ASP 500, har en powerdown-feature.
    Det er ben 3 på connectoren "P2". Det beskrives hvordan man kan aktivere denne feature, på side 17 i databladet for 500ASP.
    Se det på datablad for ICEpower500ASP i pdf file her
    Når det aktiveres, lukker ICEpower modulet øjeblikkelig ned, og man undgår evt. blobs i højtaleren.
    ____________________
    __________________
    Mvh. Peter Pan. Se Link her. DIN kabler.    Mit set-up.    B&O + meget mere.
