Latest post 11-23-2010 1:31 AM by Keith Saunders. 1 replies.
Page 1 of 1 (2 items)
  • 11-22-2010 8:51 AM
    • Tibby
    • Not Ranked
    • Joined on 11-21-2010
    • Posts 1
    • Silver Member
    Pronto Hexa codes to Beo5
    Hi!
    I just got my first beo5, and my local dealer gave me access to Beo5 config tool.
    Now my question is, how can I get proto hexa codes in to at xml sheet that works
    with my beo5, please tell me step by step.
    Programs I have now are:
    Beo5 xml generator
    The Lingtronic program (no hardware)
    Beo5 Configuration Tool
  • 11-23-2010 1:31 AM In reply to
    Re: Pronto Hexa codes to Beo5
    A Very Warm Welcome to Beoworld..
    What Pronto HEX codes do you have an depending on what protocol they decode too, will govern what you can do with your existing resources.
    No matter what the codes are, you will need to convert them into a useable form. The Beo5 XML Generator will ONLY take Lintronic formatted timing and convert to Beo5 XML RAW format or take RC5 known address and command codes and convert them, so knowing what you are wishing to convert is the first step.
    Please add the Pronto HEX Codes you wish to convert into a zip files and add it to your posting for me to review.
    Regards Keith....
