A Very Warm Welcome to Beoworld..
What Pronto HEX codes do you have an depending on what protocol they decode too, will govern what you can do with your existing resources.
No matter what the codes are, you will need to convert them into a useable form. The Beo5 XML Generator will ONLY take Lintronic formatted timing and convert to Beo5 XML RAW format or take RC5 known address and command codes and convert them, so knowing what you are wishing to convert is the first step.
Please add the Pronto HEX Codes you wish to convert into a zip files and add it to your posting for me to review.
