Latest post 10-30-2010 1:48 PM by Bentleyman. 1 replies.
Page 1 of 1 (2 items)
  • 10-30-2010 12:55 PM
    • pavur
    • Not Ranked
    • Joined on 10-20-2010
    • Posts 4
    Signal splitter for PowerLink.
    Hello,
    I would like to ask some guy which is expert in electronic area for sketch of signal splitter (joining of signals) for PowerLink.
    Reason is I want to use two sources of PowerLink signals to one speaker. I know that normaly it solved by MasterLink connection but It will be so dificult for me to put to the walls new cable.
    I found on internet this sketch of splitter see attached picture please, but I don't know if I can use it also for PowerLink.
    Thanks a lot.
    BR Pavur
  • 10-30-2010 1:48 PM In reply to
    Re: Signal splitter for PowerLink.
    I have absolutely no idea Pavur - but you may want to speak to Steve at Sounds Heavenly...
    http://soundsheavenly.co.uk/contact.htm
    Michael
    BV5, BV Avant, MX4000, MX1500
    BS 7000, BS 5500
    Penta III, Penta II, BL 4000, RL 60.2,  RL 35, CX-100 Alu
    BL 7000, MCP6500, MCP5500,  BL 5000,  Beo4 (x2), BL 1000 (x2)
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
